Rear End Question
Old Jun 6, 2006 | 08:32 AM
vortecblazer4wd's Avatar
Rear End Question
Anyone know if a 98+ LS1 rear end will work under a '95 Z28 convertible. If so, will I need to change anything, or will it just mount right up. Are brake lines and master cylinder from LT1 ok to use with LS1 brakes? Will springs and traction bars be same? Thanks,
Dion
Old Jun 7, 2006 | 09:01 PM
MyShibbyZ28's Avatar
Re: Rear End Question
Everything is the same. Just make sure you get the brake calipers from the LS1 car too.
Old Jun 7, 2006 | 11:05 PM
But you do have to verify that the new rear has the same ABS (3-channel) or ABS/TCS (4-channel) setup as your 95 has.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
