Nitrous with a cat?
Old Nov 8, 2002 | 06:11 PM
jimbo95Z28's Avatar
Nitrous with a cat?
Just wondering if any of you would worry about spraying with a cat. I did a search, and found nothing useful. I have been spraying a 75 without a cat, and I am about to spray a 100. I put my cat back on, but I was wondering if you think that I should put my off road pipe back on before I spray the 100? Thanks
Aaron
Old Nov 8, 2002 | 09:17 PM
Z28ROC's Avatar
It will be fine with or without a cat. Although you'd probably pick up a few HP with the O.R. pipe. What's the reason for puting the cat. back on?
Old Nov 9, 2002 | 01:47 AM
oil pan 4's Avatar
why do you want it back on?
Car inspection due?
I would only put it on if I gutted it.
Old Nov 9, 2002 | 01:46 PM
AutoRoc's Avatar
yutiuyt7
I'd suggest a Cut-out welded in front of the cat(s). Uncap it whenever you want to spray the car. The nitrous would appreciate the lack of backpressure
Old Nov 9, 2002 | 08:10 PM
jimbo95Z28's Avatar
The reason that I put the cat back on was that I just got a ticket for drag racing, so right now, I want to bring as little attention to myself as possible. Not to mention, my car is not tuned at all, and it runs smoother with the cat. After or while I get tuned, I will put the ORP back on, but I would rather the cops not be able to hear me from 3 blocks away. I already sprayed the 100 through it, and there sure is a big difference going from a 75 to a 100. I just can't wait to spray a 150
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
95blkss
Sep 22, 2015 03:18 PM
Sep 11, 2015 09:44 AM
