Where to get vacuum for gauge?
Old Jun 3, 2006 | 06:24 PM
slayer6x6's Avatar
Wheres the best place to get vaccum for a vaccum gauge? The only ones I see are for the purge valve and the booster.
Old Jun 7, 2006 | 05:43 PM
slayer6x6's Avatar
Re: Where to get vacuum for gauge?
come on, somebodys gotta know!
Old Jun 7, 2006 | 11:54 PM
blacknight's Avatar
On the driveside there is a vacuum line that goes from the fuel purge selonoid to the intake. It's a hard plastic line. It has clips that need to be opened with a flathead screwdriver. I got some 3/8 vacuum line and a T- fitting for this.
Old Jun 8, 2006 | 02:15 PM
slayer6x6's Avatar
Ohh ok, you cut the plastic line and used some rubber hose with a t fitting. You wouldnt happen to have any pics would you?
Old Jun 8, 2006 | 05:27 PM
blacknight's Avatar
No dont' cut the plastic line just remove it. Then cut a few inches of vacuum line and install that into the intake. Then install the t-fitting into this line and then cut some more vacuum line to go from the t to the fuel purge.
Old Jun 8, 2006 | 07:11 PM
slayer6x6's Avatar
Cool, thanks man!
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
