Has anyone tried?
Old May 31, 2006 | 02:02 AM
tbonebuggs's Avatar
Has anyone tried?
Has anyone tried the Turbonator (turbonator.com)? If so is this reliable and ok to use for bolt up power for a Camaro?
2000 Chevrolet Camaro: Pewter 3.8L V6
Old May 31, 2006 | 07:45 AM
MustangEater82's Avatar
Re: Has anyone tried?
no its a waste of money.
so is the tornado, whip it style nitrous kits, IAT tricker mods on ebay and all the other too good to be true mods.
best mods for a v6... (and most cars)
Routine maintenance(make sure everything is working 100%)
intake
exhaust
LSD
gears
Suspension.
On a budget...
Intake, go to home depot make a homemade smooth bellows, descreen the maf, then shave the fins off of your lid.
Exhaust, get a cutout and get it installed just before the rear axle
LSD/Gears, get a used rear off of a v8 car and swap it in.
Suspension, to be cheap just throw on a set of z28 sway bars, nice upgade that is dirt cheap.
you can do all of the above for like $400-500, might be different if you have to reporgram the PCM for the gear swap.
Old May 31, 2006 | 02:50 PM
MarcR94v6's Avatar
Is it hard to install Z28 sway bars?
Old May 31, 2006 | 04:02 PM
jonathan_abilene's Avatar
easy
Old Jun 1, 2006 | 01:05 AM
MarcR94v6's Avatar
I'm not familiar with suspension, installing z/28 swaybars would do what exactly? Sorry, I don't know sway bars from bushings.
Old Jun 1, 2006 | 02:54 AM
All you need is a
1/2 deep socket.
13mm deep socket
13mm flat wrench
Pretty easy swap. I got my sway bars for $20 local.
stock on a 2k are 28mm and 15mm rear.
stock z28 is 30mm/19mm.
makes the car handle better, It helps keep the car "flatter" in corners, but you will notice a teeny little bit more of oversteer with the setup.
Old Jun 1, 2006 | 10:37 AM
MarcR94v6's Avatar
cool, I don't mind a tad oversteer on a car that has understeer.
Old Jun 1, 2006 | 03:13 PM
94Camaro's Avatar
i would rather have the sway bars off of a 1le...
1LE:
32mm front / 21mm rear.
Z28:
30mm front / 19mm rear.
Old Jun 1, 2006 | 04:06 PM
MarcR94v6's Avatar
Well I'd take either as an upgrade, but I will get a 1LE before a Z28 swaybar if I can find one, thanks.
Old Jun 1, 2006 | 05:03 PM
Mr. Merk's Avatar
some 1le's had 19mm rear
and the early V6s (95) have 30/17mm in case you come across some freebies
Old Jun 1, 2006 | 05:27 PM
MarcR94v6's Avatar
what's 94 stock v6 sway bar size?
Old Jun 1, 2006 | 09:02 PM
94Camaro's Avatar
Well I have a GM Rebuild kit sitting here (info packet).
from the factory every 3.4L V6 / Z28 made in 1994 got a 30mm front sway bar, and every 3.4 got a 17mm rear. the z28 got a 19mm rear. the 1LE got a 21mm rear.
the 95's are probably the same (3.4). the Z28 got 30mm/19mm and the 1LE got 30mm/21mm (interesting..thot it was 32...maybe 32 is a later year)
Old Jun 7, 2006 | 12:46 AM
2002OrangeConv's Avatar
Originally Posted by MustangEater82
On a budget...
Any additional write up on this??? Pictures???
Thanks.
Old Jun 7, 2006 | 03:24 PM
Tru2Chevy's Avatar
If you will be working on your own car, these will quickly become your two favorite sites (besides a good message board):
Install University - http://www.installuniversity.com/ins...sity/index.htm
Shoe Box - http://shbox.com/1/how_tos.html
- Justin
