will 350 heads fit on the 305?
Old May 30, 2006 | 07:55 PM
2strokefreak's Avatar
ive got a set of 202 heads from a 350 wandering if theylle fit on my 305?
Old May 30, 2006 | 07:59 PM
Honda Hunter's Avatar
Re: will 350 heads fit on the 305?
Ill go with no. Never heard of it being done.
Old May 30, 2006 | 08:00 PM
anybody know for a fact?
Old May 30, 2006 | 08:07 PM
Do a search. I just did and what I learned was yes they will work but will drop your c/r to the 7's lol.
Old May 30, 2006 | 08:08 PM
c/r?
Old May 30, 2006 | 08:10 PM
fastchevy's Avatar
Yes, they will fit. The 305 heads have a smaller combustion chamber.
Old May 30, 2006 | 08:12 PM
would they be the best heads to use?
put nice valves and roller rockers on em!
Old May 30, 2006 | 08:13 PM
compression ratio. just go with a good aftermarket 305 head.
Old May 30, 2006 | 08:20 PM
my dad runs 2 pick a parts in houston and can get me alot of different heads but not really aftermarket ones and i know these 350 heads are the biggest valve opening u can get so i was assuming they would work the best for maxximum power but im apparently wrong so what other stock style heads from any chevy give me the max power even if i have to have them ported and polished?
or would i be better off just getting the stock ones fixxed up?
ive got about 600$ to do the job
thkzz for the help all
Old May 30, 2006 | 08:34 PM
Search > Joo
http://web.camaross.com/forums/showt...ight=305+heads
Old May 31, 2006 | 12:14 AM
ive been doing some searches with not much luck found some other cool stuff but not really what im looking for.
Old May 31, 2006 | 06:42 AM
teke184's Avatar
wouldn't some vortec heads bolt right up to the block?
i know you'd have to get a new intake due to some bolt and angle differences, but the vortec heads outflow the stock 305ers.
but you'd have to research what the combustion chamber sizes are, if you go too much bigger than the stockers, you'll lose compression, and power in turn.
although you could have them milled, but you can only go so far with that.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
