Compucar wet kit with NOS fogger nozzle and .047 and .053 jets- what hp shot is this?
Old May 30, 2006 | 12:13 PM
indirocz28's Avatar
Hey i've got a compucar wet system with an NOS fogger nozzle that came with .047 and .053 jets.. what hp "shot" are these jets?
Also- would it be safe to run this kit on a mildly built M6 LT1 with stock compression ratio pistons?
Old May 30, 2006 | 12:25 PM
nfa's Avatar
nfa
Re: Compucar wet kit with NOS fogger nozzle and .047 and .053 jets- what hp shot is this?
100 hp and 125 hp, I believe. SOmeone correct me if im wrong
Old May 30, 2006 | 01:49 PM
indirocz28's Avatar
so i still need to buy a fuel jet for either of the 2 jets supplied with the nozzle correct?
Old May 30, 2006 | 02:32 PM
1SlowFormula's Avatar
A Nitrous jet size of .047" or 1.1938mm should produce: 99.76 HP with 1 port. The required fuel jet size should be 0.026" or 0.662mm, and the actual HP to the wheels: 84.80 HP
A Nitrous jet size of .053" or 1.3462mm should produce: 126.86 HP with 1 port. The required fuel jet size should be 0.029" or 0.746mm and the actual HP to the wheels: 107.83 HP
Results thanks to robietherobot's calculator, based off of stock fuel pressure...
Old May 30, 2006 | 02:57 PM
indirocz28's Avatar
yeah- i use that too- but i guess i forgot to look at what it said the fuel jet i would need was..
lol
Old Jun 4, 2006 | 04:44 AM
Joe B's Avatar
My opinion would be to start with a fuel jet a couple to a few sizes larger than what many of the jet calculators come up with..Iv'e found several of them to give jettings that are too lean to start with....you can always go leaner after you check things out while it's running, but if you start too lean it's all over
mightymouse383
Jul 20, 2016 07:34 AM
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
SAR2K
Sep 1, 2002 10:49 AM
