porting the heads and throttle body
Old May 30, 2006 | 09:27 AM
maro z28's Avatar
Thumbs down porting the heads and throttle body
Looking to port the throttle body on 2002 z28 (5.7l ls1 auto).Worth buying a 90mm tb and 90mm intake manifold(tsp) or stay stock with the intake and port the tb myself? Think I have a stock 75mm ls6 manifold. Same basic question about the heads. I have a friend who can do it for a reasonable price I'm sure, worth buying new heads. ($1600 through tsp)
Old May 30, 2006 | 10:19 AM
teke184's Avatar
Re: porting the heads and throttle body
would help if we knew what the setup was on the rest of the car.
porting the TB is not a bad idea on any engine. it won't make a huge difference but it can't hurt (if done right).
the big intake manifolds like FAST LSx are not worth the cost on a bolt on car. if you are running a big cam or a h/c setup you'll see benefits. but it's still alot of $$ to fork over for 15hp more over your ls6 intake.
and heads are the same way. if you are running a cam than the heads can free up alot of power. but on stock cam the gain is minimal.
and budget porting is just that...budget. you never really know what you will get. your buddy could easily screw up the heads enough to actually hurt performance.
more info is needed for a better answer
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
