brake help..please
Old May 28, 2006 | 11:39 AM
jutt26's Avatar
brake help..please
Ok folks.
I am in the middle of changing the front brake pads and with the new pads on, I cannot get enough clearance to clear the spacers on the end of the caliper bolts (approx 1/8 to 1/4 of an inch).
The piston caliper is colapsed completely.
Edit: this is the only thing I can think of...however it will not colapse any further and appears completely flush with the bracket.
I remember this issue on my 91, however can't remember for the life of me how I finally corrected it.
Any assistance would be greatly appreciated.
Old Jun 3, 2006 | 03:40 PM
jutt26's Avatar
Re: brake help..please
anyone?
Old Jun 4, 2006 | 08:09 AM
RE AND CHERYL's Avatar
Sounds like you either have the wrong pads or rotors. What did you change?
Old Jun 4, 2006 | 09:19 AM
respectirocz's Avatar
crack open the bleeder to see if the piston will compress a little more
if it does, your brake hose is clogged, time for a new one
if the piston surface is perfectly flat with the caliper body then dont waste your time opening the bleeder, i would say check the parts at the parts store, bring your pads in and ask to see a second set of pads, compare thickness
Old Jun 4, 2006 | 09:57 AM
jutt26's Avatar
i was just planning on changing the pads...I think the material thickness is just too much...never seen that much material on pads before (almost 7/16 on each pad)
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
