Part #'s on zex jets
Old May 27, 2006 | 01:53 PM
jkucz31's Avatar
I just picked up a used Zex dry kit and it doesnt come with the jets, What i need to know are the zex jets part numbers for my 94Lt1...... The kit also doesnt come with some 2$ hose ,not sure what the 2 dollar hose is by the way
Old May 28, 2006 | 02:38 PM
MILESF's Avatar
Cool Re: Part #'s on zex jets
Jake, I don't have the stock numbers but, here is what you need for the nitrous and the fuel jets:
75 HP will need #40 nitrous jet and #82 fuel jet.
100 HP will need #46 nitrous jet and #78 fuel jet.
125 HP will need #52 nitrous jet and #73 fuel jet.
I'm sure ZEX can provide these.
The hoses that came with the kit were 2 -3ft. lenghts of rubber hose that connected the nitrous management unit to the vacuum fitting and to the fuel pressure regulator. The other hose was used to install the in-line fuel pump.
Hope this helps.
Fred
Old May 28, 2006 | 10:00 PM
jkucz31's Avatar
cool thanks the used kit im getting doesnt come with an in-line fuel pump but it does come with an in-tank walpro 255 fuel pump.
Old May 30, 2006 | 07:58 AM
izzyz28's Avatar
I believe you can also use Nitrous Express jets as well, since they have the correct taper. You will also need to change your fuel injectors to a non-disc type, as the stock units will lock up when the fuel pressure is raised(I have confirmed this, and it is very, very bad).
Old May 30, 2006 | 03:48 PM
jkucz31's Avatar
i was told its not necessary for it to work
novaiiman
May 15, 2016 11:36 AM
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
