weird feeling while driving..wtf?
Old May 25, 2006 | 07:14 AM
Wishmaster's Avatar
I looked at the suspension and it all looks to be intact!...but when I drive I can sorta feel the rear end of the car kinda sway back and forth...what would cause that?..sometimes its hard to keep a straight line while driving.
anyone know what I should lookk into?
its a 97 RS if that helps with 109000 on the ticker.
tires are good/balanced and holding 35psi...bushings seem to be ok
Old May 25, 2006 | 05:31 PM
lookout4theyeti's Avatar
Re: weird feeling while driving..wtf?
check the panhard rod? I dunno...
Old May 25, 2006 | 06:15 PM
Angelis83LT's Avatar
replaced the shocks lately? might just be worn out rear shocks.. I know mine used to feel like it would float around in the rear and the rear shocks were pretty much done.
Old May 25, 2006 | 06:22 PM
Wishmaster's Avatar
I checked the panhard bar and it looks to be intact...I also thought it may be the shocks in the rear but wouldnt they cause the rear to bounce up and down real bad if the shocks were worn? its doesnt do that...
Old May 26, 2006 | 10:48 AM
Camabird's Avatar
If the rear shocks are gone when you go over speedbumps etc it will feel very rough and prolly sound like your car is falling apart.
Old May 26, 2006 | 12:25 PM
jonathan_abilene's Avatar
bent axle? i dunno
Old May 26, 2006 | 03:01 PM
mrwoopass's Avatar
toque arm
Old May 26, 2006 | 04:36 PM
Wishmaster's Avatar
well I found out what it was when I almost wrecked going on the off ramp on the interstate...I took it to Firestone where they have always taken care of my IROC alignment and asked the guy to drive it for me and tell me what it could be............he drove it and did the same thing.....
put it up on the rack and checked to see if the frame was bent of anything looked out or wack...looked good....then checked the thrust angle and tracking and alignment and found the front tires to be towed in a 1/2 degree in on both....fixed that and only charged me $50....I then left and drove the car and it feels ....100%...better!....
he told told me dont even compare it to my IROC cause they are totally different as far as front suspension...my ROC drives tight as hell and doesnt sway at all!....
so im happy!
thanks for the help guys!..now on to my 383 that is going in the IROC.
Old May 26, 2006 | 11:26 PM
dam, wish i had a 383, wish it was stroked... it would go in my ride NOW
BTW, what do you mean by "BLOWN MOTOR" do you mean its blown or do you mean somethings wrong with
the internals? If its the internals, whats wrong with the internals or do you not know?
Old May 27, 2006 | 02:27 AM
Wishmaster's Avatar
I was told it threw a bearing..or something...alls I know it knocks big time! and loses compression.....almost didnt make it home...Im gonna sell everything that is still good...do a search on thirdgen and you can see my motor.....
Old May 27, 2006 | 03:35 PM
losses compression might be a bad head gasket or bad piston rings...
wait, you said it LOSSES so that could be a valve.
Nayr
Mar 3, 2023 08:34 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Bxlt1
Sep 29, 2015 03:18 PM
colts0455
Sep 27, 2015 01:07 PM
