View Poll Results: What would you do?
Use spacers/longer lug studs
0%
Put the stock brakes back on
100.00%
Voters: 3. You may not vote on this poll
Wilwood Calipers + Aftermarket Wheels = Teh Suck!!!
Well I got my Speedy Envy wheels and they dont fit over the Wilwood brake kit I have up front. The rear wheels fit fine. So right now I have two options...
I need about a .25" spacer for the wheels to clear the Wilwood caliper. I would also need longer lug studs. The wheels are already a 38mm offset, and the spacer will push them out even farther. For the spacers and ARP studs im looking at another $60-70.
My second option is to just put my stock brakes back on, and sell the Wilwoods on ebay.
What would you guys do???
Re: Wilwood Calipers + Aftermarket Wheels = Teh Suck!!!
If the wheels are going to stick out past the fender with the spacer then i would put the stockers back on. If they dont stick out then keep the wilwood setup.
I agree....It also depends on if you want to put another $74 into it.
I think im just going to put the stock brake setup back on for now. I may end up going with the C5 setup. There should still be plenty of room with the C5 brakes. Its just that the overhang on the Wilwood calilpers is ridiculous.
I tried the 56mm offset C6 wheels before and they didnt fit, but I thought I would be ok with a 38mm offset. But I guess not...
carguy0119
Apr 11, 2016 11:11 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
