Summer in Miami...Need help w/ A/C problems!
Old May 23, 2006 | 09:41 AM
DontMixWithRice's Avatar
I've just put in an LT1-t56 swap in my camaro and my air is not working.
i dont know anything about a/c and im wondering if you guys can help me.
right now, i have air blowing through the vents but its hot air.
what should i check?
no air gives me road rage!!!
Old May 23, 2006 | 09:58 AM
CheshireCat's Avatar
Re: Summer in Miami...Need help w/ A/C problems!
I feel your pain... I lived down there for 8 years... The bad news is that it is even hotter here in Central Florida...
Honestly, if you don't have all the tools (Gauges, code scanner, ect...) you're better off taking it to a shop and letting them check it out for you...
If you have all the tools, then start by checking the fuses and scanning the pcm to see if there are any codes that would prevent the compressor from engaging.
If you are too low on R134 then the pcm should throw a code and disengage the compressor clutch...
Good luck,
Steve
Old May 23, 2006 | 10:05 AM
thanks alot...i need to take it somewhere soon...
Old May 23, 2006 | 11:08 AM
jy211's Avatar
Eagle Overhauling....or call this guy, Angel 305-472-8865, not sure if the number works. Tell him a Jay from Classic Re-creations gave you his number
Old May 24, 2006 | 02:49 PM
you da man!i bought a dryer from them a while back...and i lost their number! do you know their address?
HectorM52
Jun 23, 2016 08:42 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Feb 5, 2015 05:25 PM
big dave
Sep 4, 2002 06:53 AM
