Foglight Question.
Old May 22, 2006 | 05:28 PM
Mushijobah's Avatar
Foglight Question.
How the hell am I supposed to reach in that tiny area to change the bulb? From the bottom looks like more work than from the top....There is a huge plastic guard where it is. Any of you guys done this?
Old May 22, 2006 | 05:49 PM
MARKTHOMASBRAND's Avatar
Re: Foglight Question.
Hi there,
When I changed the front fog lamp bulb on my 95 I comletely removed the lamp unit.Above the centre of the lamp there should be a spring loaded screw which can be adjusted to aim the light beam of the lamp,remove this screw.Either side of the lamp there should be a plastic rivet which the lamp unit pivots on,gently remove these with a flat bladed screw-driver.The lamp unit will then be free of the car,then just unplug the bulb and fit in the new one.This is how I changed my bulb,don't know if this is the correct procedure but it worked for me,best of luck,Mark.
Old May 22, 2006 | 06:05 PM
Mushijobah's Avatar
Thank you Mark. I will go out right now and check it out.
Old May 22, 2006 | 08:31 PM
Mushijobah's Avatar
It worked!!!! But I lost one of the rivits (damnit!). Do you think an auto shop would carry a rivet like that?
Old May 23, 2006 | 04:35 AM
Hi,
Glad you got the bulb sorted.When I did mine I broke one of the plastic rivets.I shouldn't worry about it too much.The lamp is held pretty securely by the spring loaded screw,so it's not going to fall off.I just put a regular screw in there,it's only a pivot point.
I would imagine that the plastic rivets would only be available from the main dealer.
I love my camaro,but I wish Chevrolet had put a little more thought into the replacement of wear and tear parts,like bulbs etc.
Hope this helps,Mark.
Latronaxe
Jul 20, 2015 12:00 PM
PROJECT X
Apr 17, 2015 12:13 AM
94-3.4
Oct 27, 2002 03:37 PM
newbielt1
Oct 15, 2002 09:29 PM
bman555
Aug 27, 2002 09:13 AM
