Blinker won't blink
Old May 22, 2006 | 03:21 PM
Steve76's Avatar
Blinker won't blink
I have a 2000 SS, and the left front blinker won't come on. I have changed the bulb with no luck. When I turn on the blinker, the arrow on the dash comes on solid, instead of doing the normal fast blink for a burnt out bulb. Does anyone have any suggestions before I take it to my mechanic?
Old May 22, 2006 | 03:59 PM
Capn Pete's Avatar
Re: Blinker won't blink
Top up the blinker fluid??
.....sorry, I had to!!
Seriously though, sounds like possibly a bad ground situation. Check all the wires going to the plug for that signal light, and even trace back the ground wire(s) on the left side around the headlight and everything. I know the exact same problem was happening with my winter beater ('78 Malibu!) and it turned out to be a broken wire connector going into the light socket for one of the signal lights.
Old May 22, 2006 | 09:24 PM
OBE1 95Z28's Avatar
It's likely your turn signal flasher.
Here's the location on a 1995 thanks to Shoebox's site; not sure if yours is in the same place. http://shbox.com/1/flashers.jpg
Old May 23, 2006 | 08:18 AM
Steve76's Avatar
I have checked the bulbs, the only one that won't light is the front left, and replacing the bulb does not help. My right blinkers still flash, does that clear the flasher unit, or do the right and left blinkers work independantly?
Old May 23, 2006 | 09:32 AM
OBE1 95Z28's Avatar
The light socket may be dirty or poor wire connection.
Old May 23, 2006 | 04:50 PM
Capn Pete's Avatar
You could switch bulbs with one you know works to prove whether it's the bulb or not.
I still say it's a bad ground. That's why the indicator light is staying on solid on the dash.
Old May 23, 2006 | 06:21 PM
LT1Formulation's Avatar
I just replaced my 3457 bulb in my formula with a 3157 bulb... it physically fit in the socket, but after a couple minutes, the turn signal would no longer work, it just came on solid. So I changed back to a 3457 when I had a chance and it worked fine. Check to make sure the bulb you installed is correct for your car.
Old May 23, 2006 | 10:29 PM
19z28camaro02's Avatar
turn signal flasher underneath the dashboard, above the pedals, there are three, left, right, and emergency
Old May 24, 2006 | 02:40 AM
khojo16's Avatar
most definitely your flasher...had that same problem on my beater(96 saturn) and on my firebird...replaced it and never had the problem again...
Old May 24, 2006 | 08:01 AM
m6speed's Avatar
pull out the bulb and rotate it 180 degrees
Old May 28, 2006 | 10:17 PM
Steve76's Avatar
Thanks guys. A new flasher for $1.80 and I am back and blinking. The only downside is that when I asked the guy at the parts store for a flasher, he pulled up his shirt. I did not need to see that.
68camaroboltz
Oct 5, 2015 01:46 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
