Track Kill Stories Race Track Victories, 1/4 Mile Times, Dyno Numbers - DRIVE RESPONSIBLY
Another low 12sec pass
Old May 21, 2006 | 03:26 AM
LBJ's Avatar
LBJ
Same time as my last video but my mph was down due to 1500+ DA and more humidity......
Click here to see Video
Old May 21, 2006 | 08:53 AM
myslowcamaro's Avatar
Re: Another low 12sec pass
good run. surprised your rear is still holding up
Old May 21, 2006 | 10:02 AM
Bow94z's Avatar
Nice run, 4:30's sounds like a 12bolt or 9" gear
Old May 21, 2006 | 11:45 AM
LBJ's Avatar
LBJ
U.S. gear made the 4.30's for GM when GM was selling the 7.5 10bolt to izuzu to use in there trucks.
I have been running the 4.30's for 2yrs with no problems.......except that I have to shift to 5th when I use the nitrous in the 1/4 mile. That will be ending soon thought cause this coming week I am putting the new Motive 3.90's in my 10bolt and make a run for "10's on the 10"
I would like to be one of the few that have run 10's on the stock 10bolt in a full weight, cam only, M6 on 17" 275/40 Nitto DR's and stock supension.
Old May 21, 2006 | 11:50 AM
LBJ's Avatar
LBJ
I beleive it is due to how i leave the line, load the rear a touch with a little slip the back out quick............i don't have killer 60's my lowest 1.75 and normally run 1.80's. The clutch I run has alot to do with it, it has grip like a gorrilla but you can slip it a touch too....RamPower Grip HD with a 300series race disk I love that clutch setup! Preloading is a must for the stock 10bolt with a M6, the only way to get a long life out of it like the A4's.
Old May 21, 2006 | 02:43 PM
arklie's Avatar
What exactly is preloading? I've never really known.
Old May 21, 2006 | 03:20 PM
LBJ's Avatar
LBJ
What "I" mean by "preloading" is sliping the clutch and get the car to roll out a bit before backing off the clutch really quick. It just gets all the drivetrain tight or takes the "slack" out so you don't shock the small ring & pinion in factory 10bolt. The A4's stall converters do the same but much quicker.
To make it short......if you dump the clutch aka side step it or back out as fast as you can the stock 10bolt will not live long.
Old May 21, 2006 | 04:09 PM
John M's Avatar
Hey - it's exactly that technique that lets some AWD car owners race 100 times without a problem while you'll see others who blow a tranny on every third race. Sometimes it's the hardware; sometimes it's the driver.
Old May 22, 2006 | 12:41 AM
robb4964's Avatar
Nice!
Old May 22, 2006 | 08:54 PM
LBJ's Avatar
LBJ
thanks yall!
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
alphaauto
Jul 26, 2015 04:40 PM
Noct
Jul 14, 2015 01:18 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
