foger nozzal aim
Old May 21, 2006 | 12:12 AM
jayws6's Avatar
foger nozzal aim
Well i just in stalled my NOS (universal )wet kit on my 96 lt1 ramair ,and the nozzel is facing right at the throttle body ,it is right at the end of the MAF senser .It looks like it will ony spray thru the right side of the throttle blades .will this cause un even spray pattern (will cyclinders 2,4,6,8 get a balst evenly)cause puddlen . It says 6 inces from opening ,but i see thes spray bars that bolt between throttle blades and intake .So any help or some one with the same set up have pics .
thanks Jay (who does not want to blow his second motor up)
Old May 21, 2006 | 06:51 PM
94Zpower's Avatar
Re: foger nozzal aim
as long as its in the center of the tube you should be fine, do you have pics of your setup? that would help us to tell you if its well doen or not.
Gary.
Old May 22, 2006 | 12:37 AM
jayws6's Avatar
pic no .as for my set up I have NOS wet fogger kit ,MSD digitail 6( its sayes for 50 hp 2 degres of retard -4-for the 100 shot ) , MSD digital window switch(on at 3200 off at 5500 ,Fuel pressure Switch, I have the ram air with the MAF right at the radiator ,does not give me much of a shot .the nozzel is in on the Right of the rubber boot thus facing the right side of the throttle blades
ChrisFrez
Feb 22, 2015 08:47 AM
Killer94z
Jan 13, 2015 12:06 PM
Not Dave
Dec 11, 2014 06:32 PM
Klypto
Aug 2, 2002 07:50 AM
APcamaro94
Jul 30, 2002 09:21 PM
