Error 20 on Monsoon cd player
Old Nov 7, 2002 | 09:14 PM
97_TA_WS6's Avatar
Angry Error 20 on Monsoon cd player
I was playing a cd today and it started to to get static and I ejected it and put it back in and it sounded like it was trying to read then it spit it out and it came up E20. I blew in it and then it played cd's but about 4 hours later it started up again and it will play a cd it just comes up e20. Does anybosy know what is going on?? do i need a new radio?? It is the Monsoon system I hate not having a cd player, the radio bites
Adam 1997 Trans Am WS6 M6 has Borla cat back,LT4 knock module,subframes,Hypertech PP+,Hypertech 160 Thermostat,Air foil,Mac Pulley,K&N filter,B&M Ripper Shifter,MSD 8.5MM wires,Energy Suspension Trans mount & Torque Mount,1LE Driveshaft,MBA Silver Shift **** with WS6 ingraved on it,SLP 21mm Rear Sway bar,Viper GTS-R Carbon Kevlar syncros in a rebuilt T-56, Throttle Body Bypass, SLP Pressure Plate & Clutch & Fernco smooth bellow. Dallas Tx
Old Nov 8, 2002 | 06:24 AM
LS1 RULZ's Avatar
You'll have to ask someone at your local dealership what the code means. There are only a couple listed in the owner's manual and none of them are of very much help. Like you need to know a code for when the CD is upside down...WTF is up with that?
Old Nov 11, 2002 | 11:38 AM
SS Aloha's Avatar
From the GM Service Technology Group training manual "Audio Systems" 19007.03-4b pages 2-26 to 2-27
If ERR appears on the display and the disc comes back out, it could be that:
The disc is upside down.
It is dirty, scratched or wet.
It is very humid. If so, attempt use after HVAC system has de-humidified the interior.
Other CD Errors
E20: Focus Error. This could occur if the disc is dirty, on rough roads or if the humidity is very high.
E21: Tracking Error. (Tracking error can be caused by blemishes on the disc)
E22: Motor Error. The CD motor needs service.
E23: Communication Error.
Dew Point Operations
Under certain cold temperature and humidity conditions, moisture in the air will condense on the surrounding surfaces. This most commonly occurs in the spring and fall when moisture accumulates on the windshield and body of the vehicle if it is left out at night. The heart of the compact disc player is a laser/lens assembly reading the disc and producing the music. When this condition exists, the player may intermittently mute or eject the disc and ERR may light up on the display. This type of reaction is considered normal, and will clear as soon as the compact disc or player has warmed up enough to evaporate the moisture.
Are you sure the disc isn't upside down? Just kidding.
Nayr
Mar 3, 2023 08:34 PM
Quickss96
Jan 29, 2016 05:56 PM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
