12-bolt
Old May 18, 2006 | 02:00 AM
GoFast908Z's Avatar
Member
12-bolt
what do you guys think of the different 12-bolt's that are available. I have a 3 channel system. And I want to maintain my ABS. What are your guys' takes on the different ones available?
Old May 18, 2006 | 02:20 AM
Klypto's Avatar
Re: 12-bolt
strange 12 bolt... keeps abs
Old May 18, 2006 | 04:26 AM
wdtiger's Avatar
Re: 12-bolt
I like the Strange 12 bolt, too. I don't have one, but they seem to be a more direct swap. It's on my ever growing list of mods... $$$
Old May 18, 2006 | 08:00 AM
respectirocz's Avatar
Re: 12-bolt
everyone likes to pay a little more for strange, the moser 12 bolt isnt as bolt in as u would like
Old May 18, 2006 | 11:37 AM
1SlowFormula's Avatar
Re: 12-bolt
I have found them within $50 of each other, so yeah for $50 I would pay more for the strange because moser is known to have QC issuse and sets the gears up to howl like a banshee...
Old May 18, 2006 | 01:34 PM
97FormulaWS-6's Avatar
Re: 12-bolt
Personally I run a Strange unit. I've had good luck with Strange for about 10 years now in multiple different cars.
What turned me off of the Moser unit was the following:
a) No through-bolt TA Mount; head MANY MANY stories about bolts backing out; this could be solved with lock-wire, but the Strange has the through-bolts.
b) Assembly Required including pressing the bearings onto the axles. The Strange units are fully assembled, with lube, and dyno tested to make sure everything runs perfect.
The Strange was for the most part a paint and install unit. No issues with things lining up, fitment, nor the abuse from me driving 20K on it so far. We'll see how it holds up next summer though behind a Solid-Roller N20 injected 396 with close to 1K fwhp on the bottle.
Old May 18, 2006 | 02:53 PM
GoFast908Z's Avatar
Member
Re: 12-bolt
what is QC and is the howling common with the Moser?
Old May 18, 2006 | 03:09 PM
Re: 12-bolt
Quality Control, and yes most people complain Moser is loud, until they change the gears at least...
Old May 18, 2006 | 04:07 PM
GoFast908Z's Avatar
Member
Re: 12-bolt
change the gears to what? a different ratio or a non-Moser brand gears?
Old May 18, 2006 | 04:59 PM
Re: 12-bolt
either gear rato's or for whatever reason they set them up themselves or have a shop do it...
RUENUF
Mar 13, 2016 03:37 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
93.FORMULA.WS6
Nov 30, 2003 10:50 AM
