EGR valve How do I test and Replace it L98 engine
Old May 8, 2006 | 08:12 AM
Robert Martellacci's Avatar
How I relace EGR valve L98 engine Engine Sevice Light tells me this is the problem.
Old May 8, 2006 | 09:53 AM
Pneumatic_Tire's Avatar
Re: EGR valve How do I test and Replace it L98 engine
remove upper plenum by undoing the bolts on the upper parts of both intake runners, unbolt the 2 7/16 screws holding the egr down, remove it. Olug the vacuum port end with your finger, then push up on the diaphragm on the underside of the valve. if it moves with your finger plugging off the port, its bad, it should hold the vacuum. If it doesnt move at all with your finger plugging it, its good. But watch out, it may move ever so slightly it will be hard to notice.
Old May 8, 2006 | 11:46 AM
Thanks for helping with the EGR problem
Old May 8, 2006 | 02:52 PM
Z28SORR's Avatar
Or you can get a cheap hand vac. pump and test it.
jocamino
Dec 29, 2014 10:15 PM
Jazsun
Dec 29, 2014 12:14 PM
naaz90
Jul 27, 2002 08:22 AM
