Spring time = A/C maintenance service
Well, I checked the A/C system completely. But, I would like to clean the A/C evaporator and the heater core as well. Both are located near each other, but the air conditioning evaporator is reachable thru the engine bay, behind the PCM, and the heater core is reachable in the cockpit, pass side, behind the glove box.
Sooooooo, where do you think is the better access to both in order to clean them thoroughly? Some specific cleaner you had used and recommend to me?
Problem is, the dirty fins mainly...these assemblies have trapped dust, insects and tree leaves debries among their fins...a lot...8 years...you wonder....Besides, I have noticed the blower don't flow the enough quantity air thru the 3 speed settings...the 4th speed setting is more noise than air....
I'd want to apply air vacuum and cleaner/tap water(?).
Thanks a lot for your imput.
Dochidalgo
Dochidalgo
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
