Are there ANY prgmrs worth it, or do I need to LS1edit?
Old May 6, 2006 | 08:36 PM
blackrat's Avatar
Going to be swapping my diff gears soon and am going to need to change the speedo setting for that. On top of that I have the 160* stat but still have the stock fan settings.
A local shop charges over $300 just to get the basic settings in through LS1edit, but for a little more I could get a tool that lets me do it myself. I know the hypertechs are garbage as far as tuning goes, but I know a lot of other programmers were released since then (crane, diablo, pred etc. ). How are they as far as the tuning tables go?
Basically, is it worth it to spend a little extra for a non-hypertech programmer or should I just get a LS1edit "tune" for just the gear ratio and fan settings?
Old May 6, 2006 | 08:47 PM
rwb's Avatar
rwb
Re: Are there ANY prgmrs worth it, or do I need to LS1edit?
If you are going to get a programmer, get the HP Tuners. It is really easy to use, though tough to figure out what you want when you order.
Old May 7, 2006 | 06:21 PM
blackrat's Avatar
Is the "tune" function on it worth anything, or is it like the hypertech?
Old May 7, 2006 | 06:56 PM
Greed4Speed's Avatar
HP is like LS1edit.
Old May 7, 2006 | 11:01 PM
SSpdDmon's Avatar
If you just want to correct your fans/speedo, you can get that done with a mail order tune. Texas-Speed, LS1 Speed, and MadZ28 are just a few that might be able to help you out with minimal downtime.
Old May 8, 2006 | 02:29 AM
sssalah's Avatar
Originally Posted by Greed4Speed
HP is like LS1edit.
Plus the scanner and the ability to use it on more than 1 car.
Devinfoote87
Feb 12, 2016 03:21 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
