Car starting problems!!!!! HELP
Old May 6, 2006 | 03:04 PM
redlined4816's Avatar
ive got a 98 Z m6 and the last three times i started it (or tired) i turn the key to start it and nothing happens. turn the key again it starts and then stalls, turn the key again it starts and runs fine. No check engine light car runs fine after it finally starts...what could this be?????
Old May 12, 2006 | 08:23 AM
TransAm9585's Avatar
Re: Car starting problems!!!!! HELP
CHeck the ignition relay in the engine compartment next to the air and egr relays. I had a problem very close to this and thats what was replaced by the dealer to fix it. you can switch out your egr or air relay to use in its place as they are the same part number from gm now im pretty sure.
Old May 12, 2006 | 01:13 PM
i figured it out it was actaully my ignition cylinder and it wasnt reading the code fromt he key
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
