Transmission Temperature Sender.
Old Jul 21, 2002 | 05:07 PM
Rich_z28's Avatar
Post Transmission Temperature Sender.
Does anybody have any information or pics on how to tap into the lines for your transmission temperature sender? Also what hardware will I need? I heard the this is a more accurate temp. reading rather than from the Trans. pan.
Thanks, Rich
~Rich
95 Arctic White Z~28
Old Jul 22, 2002 | 12:01 AM
Rich_z28's Avatar
Question
Anyone?
~Rich
Old Jul 22, 2002 | 12:17 AM
RED95LT1Z28's Avatar
Post
When i put the sender into my transmission i used the test port which is right above the shift linkage. I have the phantom electrical one and all i did was screw the sender and it's a direct fit too into the test port and i ran it back to the gauge that was it. I heard from a lot of guys on the board to do it that way.
1995 Z28 A4 Transgo shift kit, ported MAF, K&N CAI, JET airfoil, dynomax muffler, 160 Stat, Man. Fan Switch, Jet PCM, cut-out, Bridgestone Potenza RE730 245/50 ZR16, E.T. 13.69 @ 100.5 60' 2.01, Dynoed 274 RWHP, 310 RWTQ
Old Jul 22, 2002 | 07:26 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by RED95LT1Z28:
</font>
Location of test port.
Rob B 95Z A4, !T96
Tech Page
Old Jul 22, 2002 | 03:59 PM
Rich_z28's Avatar
Post
Thank you sooooo much! You guys are so much help.
Thanks, Rich
~Rich
Old Oct 10, 2002 | 04:35 PM
Bawls's Avatar
Sweet. Thanks guys, I love the search function! I just got my phantom electrical tranny temp gauge, and was worried because the instructions say I "may" have to drill.
Old Oct 10, 2002 | 08:26 PM
96z's Avatar
96z
I put mine in the test port too although I think it gives false readings. Mine are always higher than what everyone else reports. I think its from heatsoak from the tranny itself.
Old Oct 10, 2002 | 10:49 PM
Rich_z28's Avatar
Yup, I just ended up putting mine into the test port. Works Great.
Old Oct 12, 2002 | 04:20 PM
Bawls's Avatar
What's the normal 4L60E normal driving temp? I drove to the hardware store (15 minutes away) and was at 150F. Just curious.
Old Oct 12, 2002 | 05:20 PM
Rich_z28's Avatar
Thats about right for a drive of that length. If you are doing any driving of longer distances it will be around 180 or so.
Old Oct 12, 2002 | 05:34 PM
Bawls's Avatar
Sweet. thanks.
Old Oct 13, 2002 | 10:26 AM
Ken95Z28's Avatar
I actually cut into the cooler lines and put the sensor there.
It's a lot more work to do this method than the port method.
Cooler Temp Install Guide
That's the fluid temp of the tranny before it is getting cooled down.
The test port method is ok, but do to the poor grounding property of the transmission housing (aluminum) your readings might be off a little off. One way to counter act this is to attach a grounding wire to the sensor to the car.
Good luck with any way you do it.
Old May 5, 2003 | 11:14 PM
J96Z's Avatar
I used your install guide and I can't get the fluid to stop leaking from the output line from the trans to the metal line. I hacked off the line with a saw and put hose over it and it won't stop leaking despite having 3 clamps on it. What size hose did you use? I used the hose that came with the cooler which is the same one you have.
Old May 6, 2003 | 08:38 PM
J96Z's Avatar
O.k. I stopped the leak. Flared the end where I hacked it off and it's good to go now.
WobblySausage
Oct 7, 2015 02:44 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
