10% Off STS Turbos And Accessories!
Old Mar 26, 2006 | 06:24 PM
tbyrne's Avatar
TBYRNE Motorsports carries the complete line of STS turbos! We're offering 10% off all of their turbo packages along with the STS accessories that are ordered at the same time. These discounts can be taken off of the prices that are listed on our website.
Benefits of Remote Mounting
Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage.
Lower underhood temperatures. No need to worry about melting wires, hoses, or other components.
Converts back to stock in about an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Built-in intercooling. Intake piping provides ~50% intercooler efficiency. There is no need for the expense, pressure drop, and installation problems associated with a front mounted intercooler.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise in the passenger compartment.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR CURRENT SPECIALS!
WE HAVE YOUR FORCED INDUCTION NEEDS COVERED WITH - ATI, VORTECH AND MAGNUSON SUPERCHARGERS ALONG WITH STS TURBOS!
Sep 18, 2015 03:46 PM
Sep 17, 2015 11:53 AM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
