Help! what size stall do I need????
Old Mar 25, 2006 | 09:25 AM
stepuptata's Avatar
My car is show and cruise only. It has a comp cam 224/236@114-.555/.565 and slp 3.42's (stock were 2.73). My car wants to jump forward when shifting from park to drive (rpms @1000 in park and 800 in drive) will a stall help??? If, so what size??? My mods are in my sig. (the nitrous is not used,show only). Also, my car rarely see's the highway. BTW, My car has LT-1 EDIT programming. Thanks for the help and suggestions, Troy.
Old Mar 26, 2006 | 12:19 PM
sleeper94z28's Avatar
Re: Help! what size stall do I need????
get a vig or yank 3200 stall, its not too big or too small for street use. just my .02
Old Mar 26, 2006 | 01:43 PM
stepuptata's Avatar
OK, any more suggestions? Thanks,Troy.
Old Mar 26, 2006 | 03:08 PM
ABA383's Avatar
I'm a huge fan of the Vigilante...check out www.converter.com talk to their tech dept and they'll help you with the right converter for your combo/needs...
--Alan
Old Mar 27, 2006 | 12:16 AM
Cmr0z28's Avatar
I like my 3200 Vigi.
Old Mar 27, 2006 | 02:04 AM
revtime's Avatar
If your not going to beat on it then theres no need to spend the money for a vigi or a yank. They are very nice, high quality parts but you could get a good stall for what your doing for about half what they cost.
TCI makes a very good stall converter that won,t break the bank.
I have a 4000 stall Coan going in my car soon with a TH400 which might be a little much for you, I would stick with a 3000 to 3200 stall.
Old Mar 27, 2006 | 05:42 AM
stepuptata's Avatar
I was thinking on going with a TCI breakout or a b&m holeshot 2800-3000 lock-up. What do you think. Also, do I need to do any reprogramming for the stall converter? Thanks.
Old Mar 27, 2006 | 06:46 AM
MeanGreen97Z's Avatar
If it's not trying to be the fastest thing on the street then the TCI should do the trick. If you just wanna stop the surge the TCI 2400 will do it for less than 250$. No need to go all out if this isnt a track car. If you want to really improve those E.T.s then get a Vig or Yank.
Old Mar 27, 2006 | 09:34 AM
stepuptata's Avatar
do I need to reprogram my ecm? for a stall
stepuptata's Avatar
Old Mar 27, 2006 | 01:35 PM
No your current tuning should be fine
Old Mar 27, 2006 | 01:36 PM
JakeRobb's Avatar
Super Moderator
I'm impressed... I wouldn't be able to resist using the nitrous if I had it.
Old Mar 27, 2006 | 05:02 PM
ABA383's Avatar
I subscribe to the "do it once, do it right" theory...this is one area not to skimp on at all...After 10 years my Vig has paid for itself over and over....TCI or B&M aren't even in the same league at all. I've driven cars with both...Nothing drives and/or races like a good quality converter...
--Alan
Old Mar 27, 2006 | 08:24 PM
TobyZ28's Avatar
How do the Vig's stack up against Yanks?
