Plugs for Nitrous ???
Old Mar 24, 2006 | 08:33 PM
zulu723's Avatar
What would be the best plugs for an LT1 that will be getting nitrous shortly, as I want to do them once ???
Old Mar 24, 2006 | 09:08 PM
30th TA 0219's Avatar
Re: Plugs for Nitrous ???
Ngk Tr6
Old Mar 24, 2006 | 11:14 PM
camarokid24's Avatar
I use autolite 104's gaped at .040. You are gonna want to pull the plugs after your first quarter mile run to make sure you have it tuned right.
Old Mar 24, 2006 | 11:58 PM
johnny3986's Avatar
Where do you get the autolite 104's??
Old Mar 25, 2006 | 12:01 AM
scottslt1z28's Avatar
gap them at .035
ThunderRacing.com.................NGK tr6's
DONT get iridium..........stick with copper
Old Mar 25, 2006 | 12:16 AM
LUCIFER2's Avatar
i used to use tr6 but recently switched to tr55 you get more out of these for motor passes and they are also good for nitrous
Old Mar 25, 2006 | 12:18 AM
1racerdude's Avatar
No exotic metal and gapped at .035.
Old Mar 25, 2006 | 12:46 AM
2fast97z's Avatar
tr6's all the way...tr55's are usable
Old Mar 25, 2006 | 01:18 PM
Just how much HP is the engine making without the nitrous, and how much nitrous are you planning to spray? That will determine what plugs you need.
Old Mar 25, 2006 | 04:54 PM
Bow94z's Avatar
So the TR6's are not a real good daily driver plug w/ with ocasional spray?
Are the TR55's good for a 100 shot?
Old Mar 26, 2006 | 01:39 AM
97SS0594's Avatar
im spraying a 250 shot (more this summer) will the tr6's be ok?
Old Mar 26, 2006 | 09:02 AM
RedTtop6spd's Avatar
After reading this thread, maybe someone could come up with a reference chart for what heat range spark plug should be used for what levels of n2o. Stock motor and if feeling ambitious different levels of built motors as well. Harris Speed Works, Matt, feeling ambitious enough to perhaps add it to your spark plug reference chart?
Old Mar 31, 2006 | 06:28 PM
Built LT1's Avatar
I hope I am thinking of the right brand, bit I thought Zex is comming out with a new plug. I have ran stocker non platinum autolites and Denso Iridiums. Has anyone heard that these are the best?
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
Mar 13, 2016 03:39 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
bandit383lt4
Dec 21, 2014 09:12 PM
