Auto Trans Shift Point
Old Mar 23, 2006 | 05:11 PM
LesPaulGoth's Avatar
Pretty simple quick question:
When you modify an engine, and by doing so, you move the RPM band higher, increasing peak HP from say, 4500 to 5500+, will an auto Transmission (700r4 in this case) compensate, and shift later right after peak HP? Or do you have to get a shift kit to manually change the shift points?
Old Mar 23, 2006 | 10:20 PM
Re: Auto Trans Shift Point
anyone?
Old Mar 25, 2006 | 08:29 AM
12SCNDZ's Avatar
To make a 700 shift later, you'll need to do some adjusting to your governor. The governor is what makes your transmission shift. It's driven off the output shaft. The governor operates relative to road speed and centrifugal force. B&M makes a great kit to change the weights and/or springs in the governor to change your shift points.
Frank
CPT
jb4xx
Feb 2, 2015 10:00 PM
Brake_L8
Jan 20, 2015 09:44 AM
rockync7
Jan 1, 2015 05:10 AM
Sarahrope64
Nov 27, 2014 11:17 AM
