Headlight problem
Old Mar 22, 2006 | 07:40 PM
gol10dr's Avatar
Headlight problem
I have a 96 firebird. I had a problem with one headlight popping up and the other does not( no grinding noise, nothing). Both headlamps work when i flip the headlight switch. I manually cranked them up so I can have headlights. I replaced the non working motor with a BRAND NEW headlight motor ( thinking that was the problem). The replaced motor is not flipping up once i plugged it in the connector.
I did a search and found out there is a headlight relay and this is what could be the problem..
Where is the relay and what does it look like. And about what is the cost..
Thanks.
Old Mar 23, 2006 | 09:57 AM
gol10dr's Avatar
Re: Headlight problem
Anyone???
Old Mar 23, 2006 | 11:48 AM
TraceZ's Avatar
Do you have a DVM or a test light? I'd suggest you compare reading from the side that works to the readings on the side that doesnt. If one works, logic would tell me the relay is good and you have a wiring problem.
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
