WOT Tuning, Spreadsheet attached.
Old Mar 20, 2006 | 11:46 PM
TobyZ28's Avatar
Post WOT Tuning, Spreadsheet attached.
I've made a nice little Spreadsheet with my cars stock numbers (1995 A4) along with some comments and tooltips for the columns and how I got the numbers.
If you take a look at the graph though there is a noticable dip in the stock's desired AF ration at around 4800-5200 RPM. Soon after, the car goes back to a 12.4:1 ratio. I thought it may have something to do with shifts, but this is weird because A4's are supposed to shift around 5800, which is after the "dip" GM programmed in.
Does anyone have a clue why they would have done this?
Old Mar 21, 2006 | 12:21 PM
TobyZ28's Avatar
Re: WOT Tuning, Spreadsheet attached.
***fixed spreasheet link. Sorry bout that!***
Old Mar 21, 2006 | 09:17 PM
evilundisguised's Avatar
Cool... what part is stock though? The %changes vs both rpm and coolant temp are not matching my stock tables.
What part does the open loop AFR vs coolant temp vs map play in WOT tuning? Are just the 2 aforementioned ones used once WOT mode is entered? I'm just getting into using tunercat and have little experience so far...
Old Mar 22, 2006 | 12:33 AM
TobyZ28's Avatar
these should all be stock from my 95Z28 (A4) pcm
I dont know if it varies with the M6's....
I'm not at the computer with tunercat so ill have to get back to you bout the tables again. I made this spreadsheet a lil while ago
Old Mar 22, 2006 | 03:01 PM
Maybe so... I'll put together a similar sheet with my tables later tonight and we can compare.
Old Mar 23, 2006 | 07:55 PM
You've got mail, since I have no file host..
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
