dry guys inside please.
Old Nov 4, 2002 | 07:59 PM
sweet94Z's Avatar
I plan on upping the gas this winter (150-175).Anyways tell me what your fuel system consist of injectors,fuel pump,fuel pressure,fpss setting etc. lets get down to the nitty gritty on this one guys . Any input will be greatly appreciated.
Jared,
Old Nov 5, 2002 | 03:09 PM
35thanniv.SS's Avatar
Smile
On a dry setup it ok to use a stock fuel system up to a 125shot. My setup is completely stock and im not having any problems. When you upgrade I would go with injectors in the 30# range, adj. FP regulator, and a better fuel pump. Better to be safe than sorry.
Old Nov 5, 2002 | 04:49 PM
sweet94Z's Avatar
OK,will 30# injectors be enough or should I go 36# & is there one brand that works better under the extra fuel pressure of a dry shot?Thanks again.
Old Nov 8, 2002 | 12:12 AM
You wont need 36# in jectors or bigger unless your going to get nice ported heads and a huge cam. I would go with SVO (ford brand injectors), they get the job done but they dont cost as much as other name brands.
Magenta_Hearts
Mar 25, 2015 10:24 AM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 7, 2002 05:45 PM
