please help oil fittings p600b
Old Mar 18, 2006 | 05:48 PM
hulettsz28's Avatar
Does anyone else who has the procharger p600b have any pics or information on the oil fittings and lines. I have the head unit, with both fittings on it, the oil fitting has the threads on it, and i have the oil line itself, but i do not have any fittings. also, what is the other fitting on the headunit for? i have the line as well i just dont know what it is for. Any pictures or information would greatly help. Thanks alot
Old Mar 19, 2006 | 12:19 AM
96camaroSS's Avatar
Re: please help oil fittings p600b
Okay, I read, re-read, and re-re-read. Which fittings are you trying to identify?
You have a threaded fitting on the blower for the oil feed and a barbed fitting for oil drain back to the pan right?
Old Mar 19, 2006 | 10:41 AM
hulettsz28's Avatar
I have the threaded fitting on the blower for the oil line. But on the actual line itself, i have no fittings. I need one to go into the pan, and i need one to go into the threaded fitting on the blower.
Old Mar 19, 2006 | 10:42 PM
96camaroSS's Avatar
I'm taking a shot at this purely from memory since the car is sleeping in a cold garage and I'm inside where it's warm. The oil supply line has a female compression fitting on the blower end that attatches to the oil mister fitting. The block end has a 1/8" npt male fitting that needs a 1/4" adapter to thread in to a 1/4" npt hole on the block just above the oil filter for the 95-97 model years. On the 93-94 years I believe you need to install a T fitting where the oil pressure sending unit goes(at the rear of the intake valley I think).
The return is just a oil resistant rubber hose that is clamped to the barbed fitting on the blower oil return fitting. If there is only a threaded fitting for the oil return you can purchase a barbed adapter from any hardware store or a retail chain store such as Menards/Home Depot/Lowes. The fitting for the oil pan is a male thread to screw in to the tapped hole you need to put in the side of the pan just above the normal oil level with a barbed end that you slip the rubber hose on to. Hope this has helped and I appologize if I don't have any/all of the sizes correct. Working strictly from memory here.
Old Mar 19, 2006 | 10:45 PM
JWS6's Avatar
The large hose going to the pan is the return line. A push on type -8 AN hose end will work. The sending hose is a high pressure hose and I dont know the size for you.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Sandersen511
Jan 13, 2015 03:49 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
