what is the best inline pump using stock lines?
Old Mar 16, 2006 | 01:44 PM
4SFEDZ's Avatar
i just got my motor and we are expecting AT LEAST 600-700 RWHP, with a turbo setup. i already have a 255 intank walbro but what is the best inline pump i can run using my stock fuel lines, so basically one that will bolt right in?
Old Mar 16, 2006 | 02:07 PM
cndctrdj's Avatar
Re: what is the best inline pump using stock lines?
prob aeromotive. but i could be wrong
Old Mar 17, 2006 | 04:37 AM
2NastyZ's Avatar
Aeromotive is a good one and Weldon is another. I might suggest if you put an external pump on you remove the in tank one. The external pump should be large enough to support your HP so if this is so it will have to pump more fuel through the smaller pump in the tank. This would be a restriction. If the in tank pump dies then the external one will have to work harder to suck through it.
Good Luck
Old Mar 17, 2006 | 07:26 AM
boosted-lt1's Avatar
Adding another pump inline or in series will not give you any more volume, which is really what you need.
I remember a few good threads from years back that you might try searching for.
-Scott.
Old Mar 17, 2006 | 08:48 AM
97WS6Pilot's Avatar
If you already have one Walbro why don't you make a custom dual walbro setup and buy one of Lonnie's(Racetronix) Wiring Harnesses. They're supposed to be good to 1000HP. I just made a write up on here about two weeks ago in the Forced Induction section.
I'm pretty sure that you will need upgraded lines with the Aeromotive A1000 or Weldon because it will pump more than the stock return lines and fuel pressure regulater can handle.
I have a Procharger Inline Pump that will bolt right in for sale but I doubt it will support 700HP.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
pologreen97z
Dec 2, 2014 10:42 AM
