Pitman Arm wont come off!!! Help!!
Old Mar 10, 2006 | 09:51 PM
silvertripper's Avatar
I am replacing my power steering gear box on my 81 Camaro. Everything is off and unbolted but I can't get the darn Pitman arm off. Its the opposite end that connects to my steering shaft. There is a boot and a stud coming up thru the hole and I cant get it to come off! Is there a special puller to get it off? Please help! Thanks!
Old Mar 10, 2006 | 10:12 PM
94Z28WP's Avatar
Re: Pitman Arm wont come off!!! Help!!
I had a problem removing it on my 81 a few years back... If you have an Autozone, they'll loan these out...
http://www.autozone.com/in_our_store...pitman_arm.htm
http://www.autozone.com/in_our_store..._arm_wedge.htm
Old Mar 10, 2006 | 10:44 PM
I do have a AutoZone by my house, I'll get these tomorrow. Thanks for the help, I was slammin, and hammering, and wedging, and cussing the arm for over an hour. Thanks so much!
Old Mar 11, 2006 | 05:48 PM
Dave89IROC's Avatar
yeah, the screw one is the one needed to take it off the box, I remove the big nut, crank it down tight, then give the arm a few whacks with a big hammer, it makes a loud pop when it comes loose
Old Mar 11, 2006 | 06:50 PM
I couldnt get thenut loose so I detached it from the other side. Opposite side off the pitman arm. Came off then but I still cant get that darn nut loose. I think it takes 1-5/16 socket and I dont have one. I went down and bought a huge Cresent wrench and it still wont come off!
Old Mar 11, 2006 | 08:02 PM
Dave89IROC's Avatar
yeah, I always use a impact, you might need to take it to a shop, and have them pull it off for you
Old Mar 12, 2006 | 12:55 AM
94Z28WP's Avatar
I'd be afraid a cresent wrench would round off the nut... I used a 1/2" drive loooong breaker bar... You can slip a piece of pipe over the end to get more leverage.
Quickss96
Jan 29, 2016 05:56 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
