ordered a nitrous kit - anything else i need?
Old Mar 7, 2006 | 05:44 PM
kingman109's Avatar
okay i picked up a used NX nitrous kit and its my first time with power adders. heres what i got.
im also thinking i should pick up
NX-15601
NITROUS PURGE VALVE (D-6 MANIFOLD, PUSH BUTTON, AND VENT TUBE
860-010151 F-Body Bottle Mounting Bracket
NX-15718
EFI Fuel Pressure Safety Switch w/ D-4 Manifold
NX-15961
TPS Sensing Switch
that look like it should cover everything? or should i not get something or get something else? mods to car are in sig and i plan on running a 150 shot.
also... i know the Zex kits come with a fuel pump booster ... should i look into getting a booster as well?
thanks in advance... cant wait to be in the 11's this spring
Old Mar 7, 2006 | 06:09 PM
Bow94z's Avatar
Re: ordered a nitrous kit - anything else i need?
you need a bottle heater and window switch...
You'll never get enough pressure out of the cold bottle with a 150 shot.
on the shark nozzle, where is the two nuts that kinda hold it onto the elbow?
Old Mar 8, 2006 | 09:00 AM
HarrisSpeedWorks's Avatar
Yeah, bow94z brought up a good one, it would look like this:
http://www.harrisspeedworks.com/shop...cat=265&page=1
I would look into a intake pump, like a Racetronix kit, insted of the inline pump, since you already have a cam and everything.
Matt
Old Mar 8, 2006 | 09:55 AM
jsetzer's Avatar
Fuel safety switch for sure, you have a purge on it..... Looks pretty good.
Bottle heater will help.
Old Mar 8, 2006 | 12:39 PM
kingman109's Avatar
thnx guys -
as far as the nut - havent picked the kit up yet since im on vacation this week. Guy had it on an LT1 i believe and said he had everything for it, so ill have to check and make sure-
bottle heater sounds like a good idea- i was debating it so guess ill go ahead with it. -
harris - hadnt seen your site yet somehow so ill do some browsing and probably buy some parts if not all from you -
thnx again
camaroguy50613
May 27, 2016 09:00 AM
Jan 23, 2015 01:13 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Brendans Z
Sep 11, 2002 05:29 PM
