Blower Rpm
Old Mar 6, 2006 | 04:49 PM
boosted-lt1's Avatar
Blower Rpm
I was wondering where everyone spins their superchargers to. Do you spin to the Max Eff., Max Limit, Overspeed?
I am thinking about a change to a smaller supercharger pulley. I am in between the maximum efficiency and maximum limit right now.
Let me hear anything you got.
-Scott.
Old Mar 6, 2006 | 06:15 PM
OBE1 95Z28's Avatar
Re: Blower Rpm
No input on the optimum rpm to run the blower, if you haven't bumped up to a larger crank pulley yet, I suggest to increase the crank pulley before going with a smaller blower pulley. The increased crank pulley change helps reduce belt slipage. I run the 7" crank pulley and stock 3.3" blower pulley and rev my engine to 6,200 rpm.
Old Mar 7, 2006 | 09:27 AM
Re: Blower Rpm
Thanks,
A blower pulley would be cheaper. Can you still get a 7" crank pulley other than a used one? Is a belt change typically nessesary when changing either a crank or blower pulley?
Also, is there a good place to buy pullies other than Vortech?
-Scott.
Old Mar 7, 2006 | 10:15 AM
canbaufo's Avatar
Re: Blower Rpm
www.aspracing.com
I would change the crank, not the blower. Belt change, yes, usually.
Old Mar 7, 2006 | 07:39 PM
Re: Blower Rpm
I've got an old A-trim and I'm trying to get the most out of it. A swap to a 2.75" pulley would yield me 45,163 RPM, which is about 0.4% over the absolute RPM limit.
I think this might be the right way to go.
-Scott.
Old Mar 8, 2006 | 01:11 AM
BMoney's Avatar
Re: Blower Rpm
I supposedly have a A-trim too, and I bought a 2.95" pulley and I thought that would max mine out. where did you get the calculation from? maybe I did it wrong, or got the wrong info. also what boost are you looking to get?
Old Mar 8, 2006 | 07:38 AM
Re: Blower Rpm
BMoney:
I just made a quick excel sheet using the formula given at the Vortech site. I can email it to you if you like. I am also assuming I have the 6" crank pulley.
I am not really looking for a particular boost pressure.
How did that 2.95" pulley work?
-Scott.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
