master slave cylinder problem!
Old Mar 1, 2006 | 03:49 PM
RedZ28Beauty's Avatar
Im changing clutch right now and im by accident press the clutch pedal when the slave cylinder was deattached from tranny! The pedal was wery hard then make sound like something metall breake and went all the way down! And i tryed to press it againg and the pedal dont have any pressuer! And the slave cylinder pushrod was on the floor! What it is? How i can fix it?
Thanks!!!
Old Mar 2, 2006 | 02:02 AM
Re: master slave cylinder problem!
Any one?! NEED HELP!
Old Mar 2, 2006 | 12:09 PM
Thanks for help!
Old Mar 2, 2006 | 08:00 PM
OBE1 95Z28's Avatar
Most likely you destroyed the slave cylinder. I've never seen a rebuild kit. You can buy a replacement slave cylinder; I did from a local parts store for $70. You can also by the master/slave/reservoir combo from GM. I bought that several years ago from Dal for $83.
Old Mar 2, 2006 | 09:48 PM
IrocSS85's Avatar
one time, i had a brain fart and tried the old school trick of pushing the pedal to help slide the trans on that last inch or so, ofcourse it didnt work. ofcourse it pushed the trans FARTHER away from the fricken bellhousing and blew apart the slave cyl. just like you said. so yeah, you'll need to buy a new one. I tried to put mine back together, and decided I didnt want to get it all back together only to find out it leaked or something like that. so i just replaced it. Id suggest the same for you.
chris
Old Mar 3, 2006 | 12:27 AM
Thank you for the help!!!
Can i buy a better then stock? If i any way neet to replays it may be aftermarket?
Old Mar 3, 2006 | 06:25 AM
IrocSS85's Avatar
dont think there are any. only aftermarket master's. if you can get the whole hyd. assembly for $83 like obe1 says, Id def. do that. Im not sure where to buy it from at that price, I think I paid that much for just the slave cyl. and thats with my employee discount at a dealership.
Old Mar 3, 2006 | 06:26 AM
IrocSS85's Avatar
I think if you search for "dal" you'll find his email. Ive heard lots of people buy parts off him for a REALLY good price.
Old Mar 3, 2006 | 07:38 AM
cehan's Avatar
I think Bendix makes a replacement slave cylinder. As I recall, I found it on the Autozone website and it was something like $75-$80.
Old Mar 4, 2006 | 02:13 PM
Thanks!
HectorM52
Jul 30, 2017 11:46 AM
Ringmaster72
Mar 19, 2015 03:32 PM
Briah.hood
Feb 17, 2015 02:10 PM
Jason Short
Jan 19, 2015 06:34 PM
siguy
Nov 27, 2014 10:07 AM
