Those of you who have done the t-top conversion
Old Feb 27, 2006 | 06:22 PM
1993z28camaro's Avatar
Those of you who have done the t-top conversion and are willing to help
Is their anyone who would be willing to help me convert my 93 hardtop to t-tops. I live in ohio so red blur is kind of out of the question but those of you in indaina that have done it or even if your in ohio not sure of any but if you would be willing say in june or early july I could really use your help. I'm fine with cutting the roof I just dont know how to fiberglass and mud to make them fit correctly. Any help would be appreciated!
Thanks Kyle
Old Feb 28, 2006 | 07:46 AM
Re: Those of you who have done the t-top conversion
Anybody willing to help?
Old Feb 28, 2006 | 09:21 AM
1Quick88's Avatar
you would probably be better off replacing your car with a t-top car and transfering all of your existing mods over..i know people have done the conversion but i dont think it will ever be "correct"
Old Feb 28, 2006 | 10:36 AM
I know but I LOVE MY CAR! I have the greenish blue paint which I belive is sort of rare because I don't see to many with the same color and plus I have way to many memories with it. The car has been in my family since new. The only part that troubles me is that 93 t-tops weren't an option yet so I want them really really bad. I've already made my mind up and have attained the testicular fortitude to cut the roof and supports I just need hwlp w/the fiberglassing and bondoing.
Old Feb 28, 2006 | 12:19 PM
cwaldt's Avatar
Do a search on here and you'll find 2 or 3 how too's linked in some threads about T-Top Conversions.
Old Feb 28, 2006 | 04:29 PM
I already searched on here and have spent many long nights reading and, now I'm ready to do it and would like a little extra help from someone.
Old Feb 28, 2006 | 05:12 PM
Andrew R's Avatar
if you were closer, Id help you out.
Just take you time, and be carefull, and plan ahead on all of your cuts.
Mine has been done for about a year now, and I love it to death, and I would do it all over again. Doesnt leak for the most part either
Old Feb 28, 2006 | 08:19 PM
Thanks man. If I get desperate I might just have to take you up on your offer. A bit of a drive though.
Old Mar 1, 2006 | 12:23 AM
oneslowz28's Avatar
i did it the other day and it took me 2.5 hours tops. Its not hard at all if you have the right tools. to do it in the time i did it you need Saw zaw (saber saw), good drill and bits to drill out the spot welds, Dremel tool with flex shaft for fine tuning the finished cuts, hammer for bending the metal to match the channel, pint of bondo, tube of glasing putty, and 2 tubes of silicone to seal the gaps befor bondo. when working with the bondo just take your time and if you mess up you can always use more bondo. qstart cutting the bondo with 80 grit and once your real close to where you want it to be switch the paper over to 220 grit and then use the glasing putty to cover the whole area with a thin layer and then wet sand that with 600 grit and let dry. then spray with high build primer again sand with 600 grit and let dry then tape up all paited surfaces and glass and rubber. then spray with gloss black. let that coat flash (see time on can) then spray a second coat let flash then repete this process with clear 3 times.
Old Mar 1, 2006 | 07:17 AM
Thanks! Still sounds like more than I'm capable of doing.
Old Mar 6, 2006 | 12:52 AM
cpformula's Avatar
Where in Ohio are you located? I've thought about the conversion but not sure about it yet. If you do yours, I'd appreciate the opportunity to watch.
Old Mar 6, 2006 | 12:23 PM
I live in Radnor which is north of Delaware. I was thinking of going to a junk yard and cutting the roof of a hard top for a practice run. If you want you could help/watch or whatever.
Old Mar 7, 2006 | 01:37 PM
94Camaro_Z_28's Avatar
It's easy, just go at it. Once you get the plastic roof off, it'll be obvious how to do it.
Old Mar 7, 2006 | 02:53 PM
Its the fiberglassing and the bondoing that I am having trouble with. I have no idea how much fiberglass to put on and how far over to fiberglass.
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
WPHIG2
Aug 27, 2015 06:37 AM
