Noise comoing from rear of Car
Old Feb 27, 2006 | 03:17 PM
ptown's Avatar
The other day I was driving around town and when I slow down there's a noise that sounds like somethings winding down. I think it's coming from the rear end. It's really noticeable from like 40mph and down while stepping on the brakes.
Old Feb 27, 2006 | 09:32 PM
ptown's Avatar
Re: Noise comoing from rear of Car
Anyone have any insight on this.
Old Feb 27, 2006 | 09:53 PM
CamaroSS30thAnn's Avatar
sounds like ur rear is ready to let go
did u have gear installed they could be incorrect on the clearances?
Old Feb 27, 2006 | 10:00 PM
blown94's Avatar
obvious question, have you looked at the rear discs and pads?
Old Feb 28, 2006 | 12:47 AM
ptown's Avatar
yeah I just did the brakes about six months ago with some hawk pads.
Old Feb 28, 2006 | 07:35 PM
OBE1 95Z28's Avatar
Differential gear noise is common. A lot of guys have a leaky pinion seal that will drain your rear end fluid over time...how's yours? You could also have a bad wheel bearing. Does the sound change when you make left and right turns? Usually a bad wheel bearing will stop making noise when you turn one direction, but make noise the other direction or straight.
Old Feb 28, 2006 | 11:48 PM
ptown's Avatar
I had the pinion seal replaced a few years ago. the noise is deffinatley coming from the rear. I took it for a drive today and its almost constant at like 35 40 mph.
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
