Tranny and Console Bounces
Old Feb 27, 2006 | 09:31 AM
GMH94Z28's Avatar
I have a 94 Z28 M6 and when I hit a bump or get on it the console moves up and down. I already have the poly trans mount (2 years old) torque arm poly bushing. Does anyone have any ideas? Thanks in advance
Old Sep 25, 2006 | 01:30 PM
GMH94Z28's Avatar
Re: Tranny and Console Bounces
I am still having this issue. What connects the shifter console to the body of the car? It seem that when i hit a bump in the rear the shifter console will bounce. Thanks
Old Sep 25, 2006 | 01:51 PM
Capn Pete's Avatar
There is nothing physically attaching the shifter to the console . The only 2 things the shifter goes through are the lower boot (that is screwed to the floor) and the upper, leather boot, attached to the console. There should be enough free/loose material in the leather boot that it won't pull the console around when it moves (hence, how it allows you to shift through all 6 gears freely?). The lower boot is down far enough, I don't "think" it should be causing the console to bounce around, but who knows?! Are you SURE you've got a poly mount, and everything is bolted solid under there?? Are you sure the console is bolted down properly? Perhaps it just "bounces" when you hit bumps and it's nothing to do with the shifter at all??
I don't know what else to tell ya, dude?
Old Sep 25, 2006 | 02:00 PM
GMH94Z28's Avatar
Capn Pete,
I just don’t think the console should bounce like that. If I put my finger at the shifter console and the dash piece that covers the radio when I hit a bump I can stick my finger between them. It is like the hump under the console is loose or something. I don’t know how else to explain it.
Old Sep 26, 2006 | 12:41 AM
Dave '97 Z28 M6's Avatar
After I had the 383 installed, and added the 315 rear tires, I was getting some pretty wicked wheel hop. It would shake the hell out of the console, and the shifter would jump up and down. I've since installed tubular lower control arms and relocation brackets (to get rid of the wheel hop), and a crossbrace mounted torque arm (to move the mount off of the tranny). I don't have this issue any more.
Old Sep 26, 2006 | 08:58 AM
GMH94Z28's Avatar
Dave '97 Z28 M6
Can you define wheel hop?
Correct me if i am wrong but I thought wheel hop was when you cant get traction and the tire hops.
Mine does this just from hitting a bump. Thanks
Old Sep 26, 2006 | 10:41 AM
Originally Posted by GMH94Z28
Dave '97 Z28 M6
Yeah, that's right. You mentioned that you see this problem when going over bumps or when you get on it. I just thought about my wheelhop issue when I read that.
Old Sep 26, 2006 | 10:44 AM
GMH94Z28's Avatar
It almost feels like the transmission is pushed up against the chassis and it has no room to give when you go over a bump.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
