How do you scan for air bag SRS problems?
Old Feb 18, 2006 | 06:25 PM
94ConvertibleZ's Avatar
Hello all,
I have been working for quite some time now on a 94 V6 Vert I picked up pretty cheap at auction. The car was in a flood back in 96. I have most of the bugs worked out but air bag light is on. I cleaned and tightened the ground post by the battery and it didn't help. I presume that one of the sensors or modules is corroded from the flood because that is what I have found with some other electrical devices and switches on the car. My scan tool has no option for checking air bag or abs codes. Does anyone know how to pull a code for this or which scanner to use? Thanks for the help.
Ryan
Old Feb 18, 2006 | 06:45 PM
Dave89IROC's Avatar
Re: How do you scan for air bag SRS problems?
you will need a more expensive pro type scanner
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
