tranny speed sensor
Old Feb 16, 2006 | 01:25 AM
1996z28m6's Avatar
tranny speed sensor
When installing my new clutch i accidentally pulled out the speed sensor wiring from the actual connector...how would i connect this back?
Old Feb 16, 2006 | 07:53 AM
Re: tranny speed sensor
If you ripped the wires from the terminals in the connector, you will need to buy a new pigtail (or figure out how to remove the terminal, re-solder the wire to it and put it back in the connector).
Old Feb 16, 2006 | 09:56 AM
1996z28m6's Avatar
by pigtail...do you mean the entire set of connectors?(i.e. skip shift, reverse, and speed sensor)
Old Feb 16, 2006 | 02:31 PM
94arcticwhiteM6's Avatar
as in the connector and wiring for the speed sensor
gm number 88987993
this number has about 6 supercessions on it so if you go to a dealer it could be gray or yellow.
jmadoll
May 27, 2015 07:13 PM
jj_burchiel
Mar 21, 2015 12:51 AM
737drivr
Feb 20, 2015 11:54 AM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
