Will this hold?
Old Feb 15, 2006 | 01:03 AM
30thCamaroZ's Avatar
Will this hold?
Stock bottom end LT1 with 70k miles on it. Putting a cam in and possibly heads but at least cometics with ARP head bolts and want to spray a 150 shot on top. Who thinks it will hold?
Old Feb 15, 2006 | 05:16 AM
LameRandomName's Avatar
Re: Will this hold?
There are a few guys running 200 shots on stock bottoms.
It's always a crap shoot of course. You sometimes wont know if you have a weak spot until it's too late, but the main thing is to stay out of detonation. That, and cross your fingers.
Old Feb 15, 2006 | 06:46 AM
Bow94z's Avatar
Re: Will this hold?
it's like playing Russian Roulette
Old Feb 15, 2006 | 08:14 AM
RedTtop6spd's Avatar
Re: Will this hold?
What is basically the max a stock lt1 and ls1 bottom end will stand up to?
Old Feb 15, 2006 | 03:00 PM
Re: Will this hold?
Yeah I'm hoping I can make 550 on the stock bottom end. If I don't get heads I'll be around 500ish which should hold.
Old Feb 15, 2006 | 05:05 PM
HeavyChevySS's Avatar
Re: Will this hold?
The general nitrous rule for max shot is half the HP of the engine.
If your LT-1 makes 275 HP...you should only run a 137 HP shot. I think this is why so many people use the 125 HP kits. I know a bunch of people spray as much much as 250 shot but I don't think they care about damaging their LT-1.
I think you'll be fine with the 150 shot as long as you R/R the injectors and upgrade the fuel pump and plugs.
Old Feb 16, 2006 | 07:47 AM
HarrisSpeedWorks's Avatar
Re: Will this hold?
I too think you'll be okay on a 150 shot, as long as the fuel/tune are good. A progressive controller could help you take some of the shock of the hit off too.
Matt
Old Feb 16, 2006 | 10:51 AM
Re: Will this hold?
I think putting in cometics and ARP head bolts will be a big benefit. How strong are the rod bolts?
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
350350
14
Aug 11, 2015 12:03 PM
