Vac check valve
Vac check valve
Hello,
I have a quick and stupid question for y'all. I have a '94 camaro (3.4L, though I think this part is ubiquitous to both motors) and I need what I think is the vacuum check valve. On the pass firewall, there is a fitting with about 4 vac lines going in and out (looks like the tank feeds this fitting and then the outputs split off). Mine has a crack and so the center HVAC vents dont work.
I just wanted to see if anyone knew if you could get this part at a parts store (if so, the proper name or part number would be great since I am too stupid to find it on CSKs or AZ's site). I was hoping to avoid a trip to the dealer for what is probably a 5 dollar part (sound right?).
Thanks in advance, and sorry for such a stupid question.
Re: Vac check valve
Just picked one up from the Chevy Dealership; about $6. P/N 12124134
http://shbox.com/1/vac_check_valve.jpg
Re: Vac check valve
Thank you sir. I just picked up a couple myself. I gave up on seeing if parts stores sold them and headed over to the dealership.
Darn, I forgot about Rob's pic with the part number. Thanks for that!
Hmmmm, I think it is #14056648 for the check-valve itself....... That's what I just picked up ($6.19). Either there are a couple part numbers or the one you listed might be for a vac line perhaps........
Thanks again for the quick reply!
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
