changing gears
Old Feb 12, 2006 | 04:31 PM
chevy94c's Avatar
changing gears
I just picked up a strange 12 bolt with 3.42 gears. My car currently has 3.23 gears. Should i just pick up a power programmer or tunercat ? Any help would be great.
Old Feb 12, 2006 | 08:22 PM
quickmedic1's Avatar
Re: changing gears
If you have a laptop get tunercat and change nwhatever you want. You could also have any tuner local to you reset the speedo and the shift points for you.
Old Feb 13, 2006 | 08:48 AM
2000GTP's Avatar
Re: changing gears
A programmer will run a few hundred bucks brand new unless you get one used. A tuner can probably do that same job for under a hundred bucks.
Old Feb 13, 2006 | 06:17 PM
chevy94c's Avatar
Re: changing gears
Thanks for your help. Any suggestion on which tunercat software to get?
PCLZ28
Dec 24, 2015 05:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
