odd noise
Old Feb 11, 2006 | 03:21 PM
Dfetter84's Avatar
odd noise
i hear a noise that sounds like the tire rubbing from the left rear wheel
it is very inconsistent in that it wont do it all the time, the only consistent part is that it will make the noise only when making turns under 40
i have looked under the rear and all suspension bolts are tight and bushings look good
i doubt its the shocks because of its inconsistency. the only bad thing i see is a leaking output seal on one side.
thoughts?comments?suggestions?
Old Feb 12, 2006 | 08:31 AM
Kataklysm's Avatar
Re: odd noise
Possible hub or axle bearing noise. If its leaking I would be looking at the axle bearing.
autoxr166
Sep 25, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:25 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
