air conditioning question
Old Feb 10, 2006 | 03:27 PM
zoomie's Avatar
!994 z/28
No matter what setting I put the air controls at, I get many smells or fumes
from other cars coming into the car. Should the air conditioning be pulling in outside air?
Old Feb 10, 2006 | 06:13 PM
Kataklysm's Avatar
Re: air conditioning question
YES! Where do you think the air would come from if it didn't? What happens is the refrigerant flows in the "sealed a/c system" (they leak) and cools whats called an evaporator inside the heater box, the blower fan sucks the air in from outside and blows it across the evaporator which makes the air cold and that's what hits you in the face from the vents.
Old Feb 10, 2006 | 09:00 PM
00cls1camaross's Avatar
cant you put it on max a/c so it recurculates the air inside your car?
Old Feb 10, 2006 | 09:05 PM
Dave89IROC's Avatar
bingo,if there is no recirc position, MAX A/C is the only position that recirculates the air
Old Feb 10, 2006 | 10:53 PM
2kflhr's Avatar
I had a '94 Z and had smells, turned out to be the infamous intake manifold oil leak at the rear. The LT1's are famous for that due to the EGR tube (gets very hot) being so close to intake and causing the RTV to fail. I repaired that and the problem was gone.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
