T/A T-handle shifter knob in Camaro
Old Feb 9, 2006 | 05:11 PM
94ZVert's Avatar
T/A T-handle shifter **** in Camaro
Will any year Trans Am T-handle shift **** for automatics fit earlier Camaro's (94)? Just curious if there were any differences. Thanks
Old Feb 9, 2006 | 07:44 PM
v8pwrdz28's Avatar
Re: T/A T-handle shifter **** in Camaro
Originally Posted by SVT03
93+ should fit. Why you would want the t-handle is beyond me.
well u own a ford, so u dont need to explain lol
Old Feb 9, 2006 | 08:35 PM
6LITEREATER's Avatar
Screw the trans-am t-handle, get the one from the Impala (the LT1 style).
It fits, is much nicer and looks good in Camaro (I have one).
Old Feb 9, 2006 | 11:29 PM
rambo benson's Avatar
5LITEREATER Can you post a picture? I'm really interested in doing this on the Z if it looks a little bit "badder". I think the shifter we have looks pretty gay.
Old Feb 10, 2006 | 12:14 AM
Yeah, give me about 20 minutes...
Old Feb 10, 2006 | 12:19 AM
Great!
Old Feb 10, 2006 | 01:04 AM
Ok, so I should have cleaned the interior up a little bit but here you go anyways:
I actually keep the stock **** in the console in case I get bored with this one but haven't so far.
I do plan on cutting an inch off the stick to make the **** drop lower.
What do you think?
Old Feb 10, 2006 | 06:24 PM
What do you think Rambo?
Old Feb 10, 2006 | 07:26 PM
WAY WAY WAY BETTER! It covers up more of the wimpy tube too. Thanks for going to the trouble for those pix...I'm doing it!
By the way, I started trying to mod factory shifter by using a B&M Hammer handle, fitting it with a a tube that slides over the stock pole and cutting the pole down. Once I did that the little clipping device and button attatchment was gone. It was a disaster. The handle would spin, (should have done a square tube) and since it has to go up and down, it was so heavy it would not release unless you banged it down and then held up on it to get your key out of the ignition.
I'm only telling you this, because once you cut that pole down, I think you are screwed. Ended up installing a whole new (used) shifter dude. Unless you have a better plan, I would not try to cut that pole down.
Thanks again buddy! WAY BETTER than the WOOSY grandmother thing we have now.
Ram
Old Feb 10, 2006 | 07:35 PM
Ram
Huh, that's odd. Glad you warned me. I saw a post of a guy cutting it down. Didn't mention in problems with it. Are you sure it wouldn't work with a factory style shifter (that still uses the staple thing, which this t-handle does BTW)?
Old Feb 10, 2006 | 07:40 PM
I shouldn't say it won't work, I just don't see how.
Won't cutting it down remove the staple thing? Or change the geometry?
Having said that, I would REALLY REALLY like to cut it down myself. Let me know if you can find that post again, OK?
Best, Ram
Old Feb 10, 2006 | 07:43 PM
Best, Ram
I'll go check it out now... be back in another 20 .
Old Feb 10, 2006 | 08:23 PM
Ok, you could make it work (with a stock style handle that uses the staple to hold it in place). Here's how (assuming you want to lower in an inch):
Pull your stock **** off.
Measure an inch down on the metal (from the top of the metal) and then and inch down (again on the metal) from where the metal shaft has slots in it for the staple.
Cut and inch off the metal shaft (being very careful not to cut the plastic plunger) and then "notch" the shaft and inch down from where the factory "notches" were for the staple.
Then just cut an inch off the plunger and re-install.
Should work fine as long as you are careful and attentive to detail.
As soon as I get time I am going to do it.
Old Feb 10, 2006 | 08:25 PM
BTW a Dremel is your new best friend
Old Feb 12, 2006 | 02:34 AM
OK Great man. I appriciate you doing the Ginea Pig Thing! Sounds like you have a good plan on the notches.
I know I have all the dremel goodies! I'm going to look for an IMpala shifter now.
Thanks!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
tds1213
Nov 27, 2014 12:55 PM
redz_02
Jul 24, 2002 09:42 AM
