Help a n2o noob please =)
Old Feb 8, 2006 | 09:14 PM
SSmoked's Avatar
Okay, so my goal is low 12's. I have everything in sig except ive got a new granatelli 255lph fuel pump and 3.23 gears. I plan on buying new opti/plugs/wires, dr's, ram hd clutch, phb and some lca's. I know pretty much nothing about spraying these cars. I need to know the most cheap/safe way to get the numbers i want. The only time i will be spraying is at the track and for setup races. Any good online kits i should be looking at? Anything else i need to do to prepare my car for this? Motor/trans and rear have about 75k .. if that means anything. Thanks for any help.
Old Feb 8, 2006 | 10:27 PM
Nitro Dave's Avatar
Re: Help a n2o noob please =)
THe key to a safe nitrous system is quality parts complete with the needed safety accessories.
You will need to change your spark plugs to NGK tR6s. You may need to pull some timming since you have a custom tune.
I suggest checking out our February specials. The single nozzle wet system would work great for you.
Dave
Old Feb 9, 2006 | 08:34 AM
MetallicTrans96's Avatar
I didnt do anything at first...i put a 125 shot on and went out and pushed the button...went through one bottle and its fine
Old Feb 9, 2006 | 06:27 PM
SSmoked's Avatar
MetallicTrans96 - With thoes numbers in sig.. that is on a stock clutch and no suspention or dr's?
Loonies
N2O Tech
14
Sep 5, 2022 04:53 AM
cristian1311
N2O Tech
Jun 5, 2015 05:08 PM
blkWidow
Apr 20, 2015 09:27 AM
tbyrne
Aug 16, 2002 01:12 PM
kirschman
N2O Tech
Jul 14, 2002 07:29 PM
