Questions about Adding Nitrous
Old Feb 8, 2006 | 04:56 PM
1FRANZ's Avatar
Okay here is the deal, I have forever wanted to add nitrous to my car, however i have always been scared away from it with Horror stories of how someone blew up their engine using Nitrous.. So my question is how reliable will my engine be with nitrous. Its not a daily driver, its more of my play car so it will get used probably eveytime I drive it. Also how much should I add... 50, 75, 100, etc...
Old Feb 8, 2006 | 06:00 PM
97formulakid's Avatar
Re: Questions about Adding Nitrous
i was spraying a 150 shot for about 6 months and it was just fine. The engine will be just as reliable w or w/o nitrous. The nitrous isnt on all the time (unless you get addicted like I did) so there isnt always stress on the motor. Just make sure to do it safe (FPSS, Window Switch, Fuel pump). I actually had a nitrous backfire in mine and it fried the MAF but that was it. It won't BLOW up your motor. I think that would only happen if you were running like a 300 shot.
Old Feb 9, 2006 | 07:21 AM
1FRANZ's Avatar
Thanks for the info. What do you think is the best NOS kit? Also what I should add to it to make it more efficent/faster? Sorry I dont know alot about nitrous.
Old Feb 9, 2006 | 07:53 AM
HarrisSpeedWorks's Avatar
You’re going to want a set of colder plugs along with a bottle heater if you want consistent power (it'll maintain the bottle pressure at it's optional pressure). For the safety stuff, look into a fuel pressure safety switch along with a window switch. With the proper safety items you'll find that the bottle is a very safe power adder.
Matt
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
