Are my o2's bad?
Old Feb 7, 2006 | 09:49 PM
Dwaynez28's Avatar
Question Are my o2's bad?
When i start up my car when its cold it runs like i have a bigger cam in it and jerks,always burns a little rich,It run ok after a short warm up, still with the rich smell. Is that a possible bad o2? which one would be the bad one? Bank 1 or 2 I tried the search feature. Even after the car is hot it still has a rich smell from the exhaust. Thanks For any input Dwayne
Old Feb 7, 2006 | 11:23 PM
stingercamaro's Avatar
Re: Are my o2's bad?
Are you tripping a SES light?
If so, take it to a local parts store and have them scan it and it'll tell you which side.
Old Feb 8, 2006 | 11:16 AM
Kataklysm's Avatar
Just put a scanner on and watch the mv on the O2s, they should be fluctuating at a high rate. If they are sticking then thats the one thats going out.
Old Feb 8, 2006 | 05:11 PM
Dwaynez28's Avatar
I dont have any codes that i know of, it just barely runs until i get it raced up and going down the road, then im good, thought i might need to change one or both of my o2's--would one be more dominant than the other as far as my cranking up problem and rich smell?? Thanks Dwayne
Old Feb 8, 2006 | 05:47 PM
Stoopalini's Avatar
The O2 sensors are not used for mixture control until the motor gets up to operating temp. So I do not think your cold running problem is the O2 sensors.
I would start by checking for a vacuum leak.
Thomas.
Old Feb 8, 2006 | 07:04 PM
Dave89IROC's Avatar
Thomas.
agreed, then for a leaking injector
Old Feb 8, 2006 | 08:15 PM
Dwaynez28's Avatar
Thanks for your help. Dwayne
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
